how to install speedometer gauges and bezel
schultz9008
46
Jul 22, 2009
covington, Indiana
i just recently bought some speedometer gauges with the rpm and all that good stuff with a billet aluminum bezel and i was wandering about the easiest way to do it, beacuse i was told if i mess with the needles or whatever that it will screw up my speedometer if you could just let me know if anyone on here has any experience just let me know thanks alot
well this is a tricky situation depending on the ones you bought some require you to take off the needles which i do not recommend and some you can just slide over everything were did you get them and what brand are they?
most just slide over the needles u still have to be careful to not brake the needles.. and be carful when doing to oil pressure it falls apart when u take the screws out.
well i bought both of them off of ebay and when i take the whole cluster out how does the bezel go on? im just confused on that part really
