How to check codes?
The easiest way would be to go to your local car parts store, and ask to borrow their code reader. They should let you borrow it if you use it out in their parking lot.
um...but this car is a 92, OBDII didn't start until 96 and trust me, the idiots around here will NOT have an OBDI scanner.
how do I read them manually? there's usually some trick, like short out a diagnostic connector, turn the key a certain position a certain # of times, etc... to get the CEL to blink and let you read the codes.
It's real simple. The DLC connector is attached to the fuse box by your left foot.
The upper left pin is 1 (data) and the lower right pin is 12 (ground). If you have a error code it's being output on those pins as we speak or a heart beat (on-off repeating) if nothing is wrong. A voltmeter, 12v LED, 12v piezo buzzer, etc will let you read the codes. Long pulses are ten's digits and short one units.
You would have found this in the VFAQ.
http://www.vfaq.com/mods/wayback/BradBauer/electrical/code.html
Steve
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
