How is my setup?
AdrenilineCrash
783
Nov 9, 2002
Travis AFB, California
Well Ive compiled a list of everything I think I will need for my conversion. My goals are about 450 hp. Im gonna do all the internals and build it up N/A first. Then Im gonna put the turbo on afterwards as this is going to cost me large amounts of money. Ive compiled this list over the past year or so researching and reading and this is what I think I will need. Please tell me if Im missing something or if I dont need something.
Below on numbers 5 and 6 there are sub-numbers 1-4. On question 5 they represent different parts of the exhaust system. On question 6 they represent different turbos.
Parts To Turbo My GS
1. AEM EMS
2. ?TMO datalogger?
3. Turbo cams
4. Stronger Clutch
5. Exhuast
1 o2 sensor housing
2 exhaust
3 downpipe
4 mani
6. Turbo
1 20G
2 Evo 16G
3 18G
4 GT35R
7. Wastegate
8. BOV
9. FMIC, And all Piping
10. Knock sensor
11. MAS from a turbo 1g
12. Fuel Pressure Regulator (aftermarket)
13. 450cc or larger fuel injectors and fuel pump
14. Boost Gauge, EFT Gauge, Air to Fuel Ratio Gauge
15. Stronger Pistons and rings (either forged(8.0-8.7:1) or 2g(8.5:1) or EVO(8.7:1))
16. MLS Metal head gasket
17. Lightened Flywheel (Fidanza)
18. Full Brake kit
19. Pulley set
20. Cam gears
21. intake manifold
22. connecting rods
23. radiator
24. race head?
25. ?race block? (dont neccessarily need)
26. LSD
27. coilovers
28. springs
29. shocks
30. swaybars
31. strut bars
33. wideband O2 sensor
34. ARP hardware
35. ?fluidyne radiator? (do i need?)
Thats all folks. Sorry if its long.
-mike :talon:
is that the order your getting it in? and are you a multi-millionare? :p
No that is not the order Im getting them in and why should I buy a turbo car? I realize that it would cut my work in half or more but what other benefit is there?
-mike? :talon:
Well, your work will be cut in half, but also, tuning the car will end up being alot easier, you will get much better times by getting an awd car, and common sense plays a big factor in this also, but just my .02 cents
parts alone are gonna cost you a lot, then add the labor and tuning expenses, plus add some extra $$$ for broken parts. If you're gonna go turbo for sure, buy a turbo car and work with that. It's easier.
True parts and tuning would cost me a lot but Im gonna do all the labor myself. My dad is an awesome mechanic and he will help me. Some of the stuff I wont be able to do is the machining of the block when I rebuild and the balancing/blueprinting the rotating assembly. I just think it would be fun to build up an n/t and then do a turbo conversion. Although I am looking in to a 1g turbo FWD. I dont want an AWD, thatd be too easy.
-mike :talon:
  • Wanted 6 bolt NT water pipe
    • chrisman287
