How do you know if you have a 6-bolt?
Race94
1,151
Jan 6, 2003
Puerto Rico
Well other than looking at the flywheel, how can you know if you have a 6-bolt on the car??
I would guess a CAS sensor, but what else?
You have a 95 so unless someone changed the motor then you have a 7 bolt. Thing to note about the 95-96 motor to make it easy to identify. You will not have a Cam Angle Sensor on the left side of your valve cover. The 95-96 CAS is located under the cam gear.
