HKS Power Flow Filter cleanable?
cxx
86
3
Jan 1, 2003
Berlin, Europe
Can someone please tell me, whether the HKS Power Flow Filter is cleanable like the K&N filters? And if yes, what fluids do I need to clean the filter?
Can it happen, that (perhaps) some of the green foam gets loosen and enter my turbo?
Thanks,
Marc
No, it's not cleanable. The foam piece though is fairly inexpensive and is easily replaced (unscrew the knob on the top of the filter, remove the screen and the foam pops out).
I would go with the Apexi Power Intake. It's a dry filter that requires no maintenance and oil recharging. Some people are concerned with the oil, when applied in an excessive amount, might coat the mass airflow sensor, and affect the mass air count. It shouldn't be a problem if the proper amount of oil is applied. I'm not sure if the Apexi filter is made for the 1G turbo.
