420A high rpms at idle
95gsttsi
132
Aug 20, 2010
Sturgis, Michigan
Ok so I've looked in the forums and all I can find is 4g63 problems.. I recently swapped a bad head I've done everything to a t.... except I deleted the Carbon canister, plugged what vacuum lines that I didn't need.. no vacuum leaks also have a egr blockoff. But I had that b4 car is also tuned to 390cc injectors. The car was bogging out when I had 680's in it so I switched back to my 390's also fixed a leaking fuel line it revs up to about 2500 to 3k I've adjusted the tb swapped out tps's and nothi.g has changed
