Help with install
jayman089
357
Aug 16, 2005
Woodbine, Maryland
Hey guys, I just Recieved my Tsudo N1 cat bacl and it didnt come with any directions or anything. Is there anything that I would need to know about installing it or is it just a basic bolt on? At the opposite end of the muffler, towards the cat, there is a hole. What is supposed to screw into there? Sorry its a newbie question but I'm now getting into the tuning scene. Thanks for the input. Unfortunately, I dont get off work until 11 tonite, so the install will have to wait for bright and early tomorrow. :dsm:
~JT
Make sure you have a can of PB Blaster or a nice torch for the bolts. Other than that you simply unbolt it and slide it off of the hangers. Vice a versa
Also, if you don't have a torch, hit the bolts a few times with a hammer before unscrewing. This can break up some of the rust if it's bad and can save some bolts. Bolts that won't budge counterclockwise can also sometimes be 'broken loose' by tightening them just a hair, and then unscrewing.
:thumb:
Yea i just put on my TSUDO 3" catback along with a 3" downpipe and it was an ungodly difference. Also it sounds bad ass.
Also, could I jack up the front of the car, put jack stands under the front, then do the same for the back of the car? I know this would work but not sure if I want to be under the car when it comes crashing down. Any other suggestions on how to get enough space to do the install?
