Help With HID Low Beams
amballer82822
361
4
Jun 4, 2010
Pittsburgh, Pennsylvania
I bought New headlights with Halos.... I took out the Low beam bulb and it was an H3 Bulb.. I went to sharphids.com and bought 8000k Bulbs with ballast and everything to plug and play... Coming out of the ballast is two wiress. The Big wire connects and the Smaller wire parts off into one red wire ending with a metal piece and a black wire with the same thing... Coming out of the head light i can plug the red one in but theres nowhere to put the black one???? I thought it was a ground but its not i have no idea what to do please help???:cool:
I screwed the metal end from the black wire down where the ground wire on the projector housing is....and if you didn't get the wiring harness from the battery to the ballast just reverse the plug into the ballast
Well hope that helps you out...
  • Wanted 6 bolt NT water pipe
    • chrisman287
