help with exhaust manifold
Its recommended but not necessary. If you can't get it back on you can use some heat tape.
ya i bought it off some guy on craigslist for 50 it looks nice stainless steal im not sure on the brand thow
i had cracks all threw out my old one so it was 40 at the junkyard or something diffrent
it does'nt have the threads in on it for the screws to hold the heat shield down
it just something untill i can come up with enuff money for a dc header or something
You don't need the head shield so don't worry about it. Later down the road, if you have the money, just use some heat wrap and call it a day.
If you use the Thermo wrap, make sure you soak it first. Soaking it before installation will make the tape easier to manipulate around the manifold and will reduce the amount of fibers that come off.
If you're stressing over a heat shield then you have bigger problems at hand.
You don't need the heat shield or heat wrap. You're N/A. Turbos recommend it because there is much more heat generated
End of thread.
