Mjavant
- 0
- Mar 20, 2008
High Point,
North Carolina
Ok i have the apexi twin chamber bov on the car right now. After months of searching (literally) i cannot find any information about this bov other than most people hate it cause it only vents to the atmosphere, and how to hook it up which i have the diagram it came with. Ok, look at the diagram below and ill try my best to type out whats going on here.
The BOV had three nipples the two on the side which are supposed to just be hooked to each other and the one on the bottom that goes to the intake manifold. So the vacuum lines coming from the underside of the intake and the boost solenoid are T'ed into together and connected to the two nipples on the side of the BOV. Now this works somewhat well as it doesn't stall and it holds boost exactly where it is set with no creep or anything.
I have tried hooking it up the way Apex-i says to do it, and i hit nearly 20lbs with a little fuelcut and changed it back the way it was. Any and all help is appreciated fellas.
