Help! Strange Bucking at WOT.
Sonik
Oct 7, 2002
Here's the info:
96' TSi AWD
1G BOV (crushed)
T28 Turbo
Stock IC Piping
NGK Sparkplugs/Wires
Lately when I hit WOT, there's a strange bucking/surging in the car. What's even more strange is my boost gauge spikes to over 20 PSi (past the end of my gauge) when I generally only run about 13-15 PSi. Sparks are NGK 0.7 mm and wires are fine.
As well, as a side, when I drive at normal RPM, it seems I can hear a slight hissing sound coming from the engine bay. But this only happens when the car is moving, not when stationary. I tightened all the obvious clamps (TB, IC, BOV, Intake, etc.) so I don't know if it's a leak.
Anyone have any ideas for me?
Thanks in advance,
Jeff
Check for a vacume leak. There is a faq on the web somewhere about how to do this. Hissing would lead me to think you have a leak somewhere.
Moved to problem diagnosis.
I would think if you were spiking that bad you may be hitting fuel cut or just running too lean.
Your first step is fixing the boost spike.
