help please!!
cyrez187
359
Dec 12, 2003
kelowna,
i was woundering with a wet kit the fuel and nitrous solenoids just go into your intake pipe right?does it matter like closer to the filter or what??and another thing for the fuel solenoid,tapping into your fuel line where should i do it just before the filter or what? thanks
Yes the nozzles connect the the intake pipe and I beieve it is best to do it about 6-8 in. before the throttle body from what I have heard. Also you should tap into the fuel after the filter so that you dont have to worry about any foreign objects getting into your selenoids and holding them open.
if u have wet and say u have like 50 or 75 shot how do u knwo what fuel jet to put in for that shot of nitrous?
and when the jet says like.22 or some # on it how do u know what size that is
Well you use different jets to make a bigger or smaller shot, if u have a instruction manual it should be in there wich combinations of fuel/nitrous jets to use, otherwise you can go on the NOS brand website and there they have all the manuals that are prtty much universal.
If you have an NX kit then call NX for the jetting, NOS for your NOS jetting etc etc... Each shot has a different sized nitrous and fuel jet. As you put in a larger nitrous jet you need a larger fuel jet. Manufacturers use differnet jets for the same shots on different kits so don't just assume they are the same. It depends on the fuel pressure the kit is designed to work at.
What you want to do is call the manufacturer say I want to run X HP shot, what size jets do I need. Then you have no screw ups.
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
  • Wanted Driver Side Front Side Skirt End for 97-99
    Looking for the driver side skirt end molding. Bonus if it has the mud/rock guard.
    • ProjectDSM
  • For sale 1997 Eagle talon esi
    runs and drives located in Oklahoma City
    • Nii
  • For sale 2 bare 7 bolt motors
    bare 7 bolt bottom ends
    • Nii
