help need info on oem clutch!!
95gsttsi
132
Aug 20, 2010
Sturgis, Michigan
Ok so this is my 3rd oem clutch the first one wasn't broken in proply ### I was boost hungry! 2nd was destroyed at dsm shootout... ok so I need to know the hp and tq rating is....
If I had to guess I'd say there really only rated for factory HP levels. I know people increase boost and still run them but only a matter of time before it goes. I completely destroyed a OEM clutch on my EVO IV running 20psi and lauching it. It literally fell to pieces when I took the tranny off. So my experience is to use a aftermarket clutch for higher then stock HP levels
You could talk with Tim Zimmer aka twicks69 on here. He has been very helpful with clutch selection for me. What kind of HP numbers are you running or even a decent guess compared to others with a similar set up? Thats what I would look at to help decide what you need.
