Help! Intercooler and ABS
genegoesfast
559
3
Dec 3, 2010
Nashville, Tennessee
I'm having major issues with my VR speed intercooler kit fitting with my ABS box. My car is a 99 GSX automatic which might make my situation a bit unique. I cut a pass through for the "out" of the intercooler through the radiator support, which looks correct. When I rough fit the intercooler through the opening that I made the "in" side from the turbo smacks right into the abs box. Anybody else had this issue?
Thanks in advance for the help.
It looks as if it needs to shift towards the passenger side and raise up a bit. I do believe its supposed to mount with the threaded studs with the kit. those studs are to be put into those holes that are right above the mount.
Yeah fellas, sorry bout that. I'm a bit retarded. I figured out that this was the EVAP almost immediately after making this thread. I have since junked the charcoal box. Thanks for the help though!
