*HELP* Codes p0340,p0505,p0352 and p1294
Boost95
403
Oct 21, 2004
Wilkes Barre, Pennsylvania
I have a 95 Eclipse which is fully built with a yurbo kit cams etc. It has all the goods. I know what all the coes resemble but I dont know what to do to fix them or check them. Heres the list please help me out if you have had these codes. My car has been sitting or driving like Sh*t for months. Thanks for any help im advance. -Mike
p0340 - Camshaft position sensor - CAM A
p0505- Idle control malfunction
p0352- Emission Coil B prmary/secondary circuit malfunction
p1294- Manf. Control Fuel/Air Metering
I know where the cam sensor is,ics and the coils. As for knoign what to do to check them or the fuel air metering? I have no idea. As for the fuel air metering I was guessing my 02 sensor?? I know the idle control isnt causing my major problem. My problem is when the car runs alrigth then it will just have big misses clear up big misses etc. If anyoen has some idea throw em out ot me. Thanks alot! :confused:
I have a 95 Eclipse GS with a fully built motor and turbo. car has cams and all teh supporting mods you can think of. I am throwing the following codes. If you have had these problems then please help me.
p0340- Camshaft position sensor CAM A
p0505- Idle control Malfunction
p0352-Emission coil B Primary/secondary circuit malfunction
p1294- MANF. control fuel/air metering
I know where the cam sensor and ICS is at. but im not sure how to fix them or check ANY of them. Thanks
Mike :confused:
Mike :confused:
Did you ever figure it out I am having the same issue
