2G CEL codes P1400 and P0505?
greeneclipse
407
Jan 29, 2003
Round Lake, Illinois
need some help on this one....
i pulled two CEL codes with my logger P1400 (MAP sensor??) and P0505 (Idle Control System Malfunction)
i have a breather/catch can filter on the valve cover, new PCV valve, and I have the EGR blocked off (solenoid still attached).
I've had these things done for over 4k miles and these just popped up now.
does anyone now what i should check?
is the IDLE CONTROL motor located near your throttlebody. This motor wears out on alot of eclipses.
Is your car swinging RPM ? from 500-2000
if so it might be it.
Thats the code i got and I figured it was the ISC motor.
