Jordanbutter
- 267
- 5
- Jan 7, 2006
Colorado Spring,
Colorado
At WOT the car will not go past 5000rpm! The exhaust pops a little bit and boggs down really bad, the boost holds at 10lbs, oil pressure is at 80psi (it has been really low in idle i.e. 5psi) and the O2 volts are .94 drops to .91 occasionally for a millisecond and comes back. (keep in mind this is monitored with the blue wire mod). I did a boost leak test and found nothing. I did try to take out the fuel filter a while back but it whould not budge but if maybe the bottom bolt came a bit loose would this cause a problem?
. I would double check the timing, especially since it was messed with in the past month. Does it struggle to get past 5k, if at all?
