67goatpimp
- 874
- 0
- Jun 7, 2004
Indianapolis,
Indiana
I bought this car today i don't really know much about it, but from what i can tell it's a 4g63t swapped 90 gs ecclipse.
the car runs and idles but it HEAVY rich and will turn the ground black underneath the exhaust. I got two ECUs with the car and 8625 which i have in the car now and it will drive up to 2500 rpm but it's still dumping fuel. then i also have an 8624 that we tried putting in and i couldn't even drive the car. Any help on which ECU is N/A and which one is Turbo would be a good start. I drive it and it revs extremely sluggishly and is definately dumping a LOT of fuel. When i hit about 2500 rpm it starts bucking slightly and won't accelerate any farther. The turbo impeller does not spin freely but i can hear it spin when i am revving the motor. I can turn it relatively easily with a socket...but still far too much resistance.
The owner before me told me that they had tried a few MAF sensors with no luck. there is one wire run from the MAF harness to the ecu that wasn't in the original wire loom, but i'm assuming it has something to do with the swap.
