Headlights and Taillights PROS PLEASE!~
TheDecon
34
Mar 9, 2006
Chicago, Illinois
Hey guys I was wondering what the difference was between 95 and 99 headlights and taillights? I was fairly sure that the year made no difference due to the fact they are pretty much the same body.
Also does anyone know where I an get a supra taillight setup?
tails are exactly the same but the 95 headlights are larger i think. so if u have a 95 bumper and 99 headlghts there will be a gap but they do fit :cool:
Depends, Eclipse or Talon?
Eclipse tail lights are shorter in height, Talon tail lights are longer. If you have a Talon and want to put Eclipse tail lights you need to get a Eclipse style bumper or a rear bumper from a body kit and make brackets or weld the stock brackets higher to fit the Eclipse Tail lights.
As for headlights, all 2G 95-99 Talons use 95-96 Eclipse headlights, known as 2Ga headlights. 97-99 Eclipses use shorter (less wide) headlights called 2Gb headlights. If you use a 2Gb in a Talon or 95-96 Eclipse you will have a gap between the bumper and the lights.
Did you do a search before posting?
http://www.dsmtuners.com/forums/showthread.php?t=136800 :thumb:
  • Wanted 6 bolt NT water pipe
    • chrisman287
