Hard LICP?
pwayzjellyroll
132
Aug 1, 2005
Piscataway, New Jersey
I've been looking around the forums and vendors for a hard LICP for a 1990. The only ones i saw for 1g was 91-94. Is it even worth trying to get a hard one? Is there anyone that makes one? Or do I have to make my own. Any info is appreciated.
I don't think I have real big plans of upgrading to one. I'm not planning on running more then 15lbs on my 14b. So I didn't think it was a feasible upgrade, unless you think otherwise.
You can still easily heatsoak the side mount with the 14b on back to back pulls in a hot summer day, not to mention with a logger, you should be able to safely up the boost to about 17ish psi with a re-wired stock pump.
re-wire that stock pump and any 2.5" aluminum piping will do the trick and take it to a muffler shop and get it bent. Search for supra side mount and meth injection. Devil's own has a package on sale right now pretty cheap. These few things will help you acheive your goals.
Hmm, I have a logger just need to finish making my cable. I think I may look into a FMIC now that I read what you said. Are there any negative effects to rewiring my fuel pump before upping the boost? If not it'd be something I'm willing to do. A little at a time they say.
(P.S. Bruce, you've been an amazing help the entire time I had my car, I appreciate it)
Thanks to everyone else as well.
I was looking into the SSAC FMIC but the only thing I am weary about with a FMIC is cutting the cross beam. Plus will I be able to keep my AC/PS? It's hard to tell from so many threads around here. Some say yes, others say no. I basically am just looking for something that I can bolt up without to much cutting. I didn't really want to spend more then 400 but less is good for me to.
