HadesOmega Fire Sale!
HadesOmega
640
14
Aug 5, 2002
408, California
Here's whats left of my stuff for sale:
Apexi SAFC- Ran this SAFC in my RS and installed it on the GST after. Using ecuflash so don't need this anymore. Worked great when I was running EVO9 injectors. Now its just a reason to break into my car. Running fine last time I installed it, setup for 2G turbo already, just adjust it for your AFR. Its the same one I used for the SAFC install guide right here: http://www.dsmtuners.com/forums/art...g/354838-how-install-apexi-safc-2g-turbo.html
Asking 150
SS Clutch Line from 2G Turbo - SOLD
98 GST Rear seatbacks- Came off my 98 GST. In great shape except they are cracking a bit on top and could use some cleaning. There are some holes drilled in to the back also for an amp install.
50 OBO
Greddy EVO Catback Exhaust, I got some discovered treasure here. Pulled this off a 97 Talon TSi FWD, full 3" (60mm) Greddy EVO catback exhaust. It is in ok condition, I would rate it a 7/10. It looks to have seen some miles. The can and tip is scratched on the bottom (see pix) but for the most part its in great shape. You won't even notice the scratches when installed on the car. It looks like some fitting modifications were done to it must've not have bolted on (like my ebay exhaust) well but I think it will with the mods but it wasn't welded very well. It was also welded to the rear crossmember for some odd reason and the weld came off but there is no hole in the pipe, can hardly tell. The cat was cut like 1" from the flange so the flange MAYBE not flat but it look good. It will need a new gasket where the muffler connects to the catback piping because it broke, probably best to replace them all. I don't know if this will bolt on to stock cat as well, but it might be slotted at the flange. This is genuine Greddy the real deal here these sell for almost 600 brand new. Asking 200
More Pix here:Greddy EVO Catback
Manual 2G Antenna, If you have a non-op automatic antenna you can replace it with this and a regular antenna, easy install and save a pound or two of weight.- 30
Dual Piston Calipers- Got another set of dual piston calipers here. I did the Outlander brake upgrade and got these outlander brakes from a salvage yard. Only swapped the brackets out and used my 3000GT calipers. So it is a 2005 Outlander Calipers on 3000GT brackets which is pretty much the same as stock dual piston calipers. The brackets are painted black with VHT caliper paint, hard to tell since they're so dirty. Brakes look in excellent condition probably wasn't many miles on that outlander. Comes with the clips that go on the bracket as well. Bolt on upgrade for 2GNT, 1GNT, early 1G turbos, and 2G FWD turbos. No brake lines but your old ones should work. ASKING $75
DPC Front Drilled and Slotted Rotors 1- My old rotors from my regular DPC brakes. They are slightly warped, I felt a slight pulsating when braking hard so you'll want to resurface them. They have been turned/resurfaced once but I check how much is left and it has 24mm, 22.3mm was the min. Asking $40 obo
DPC Front Drilled and Slotted Rotors 2- 100
Got these to replace the current rotors on my car but I've since decided to do the outlander bracket/rotor upgrade so I won't need these anymore. Used but in great shape, they'll look great once you burn off all that rust.
Red RRE Rear Strut Bar- 70
I wound up getting a DC Sports rear strut bar I didn't like how this one looks or mounts but its definately functional. When I took it off I heard the chassis flex. Its red and has looks a little worn. Pictures taken next to DC bar, sorry didn't get a chance with it installed. It fits though, just have to play with it a little.
2GA Talon BLACK doorcaps- 30
Got these off a 2GA talon. They are definitely different than a 2GB eclipse doorcap because I have those too which is why I'm using these. In good shape some scratches, OEM paint is good.
420A Star Turbo Kit- 1800
Add a big expensive snail to you 420A. May start parting it out in a week or two. Need the garage space no more turbo 420a for me anymore. I AM NOW PARTING THE KIT OUT PLEASE GO TO THE FOLLOWING LINK FOR PRICESMore info here: FS: 95-99 Eclipse RS GS Talon Esi Avenger Star Turbo Kit T3/T04E (San Jose)
Rear left (driver) side lower toe control arm from RS- 30
Fixed my toe problem this wasn't the problem so I sell now, ball joint boot still in good shape. Got it off of a fairly low mileage RS. Since it is from a RS it is hollow, as in it only has 3 sides of a box.
2GA headlights- 40
Don't have my RS anymore. These are a bit fogged up, nothing a little rubbing compound and polish won't fix. Hard to see in the pictures but the drivers side I think has some scratches.
2GA (might fit B) front license plate bracket, mounts on 5mph bumper- 15 obo
2G black lighted mirror- I swapped mine for a normal mirror, didn't like the bulky mirror, hard to put broadway mirror on, and it kept falling off my windshield and had to keep gluing it back on. 15 obo
2G turbo exhaust manifold heatshield- in great shape, one of the holes looks to have lost some material but a washer will fix it! 20obo
NIB 2GNT Drivers side axle (or the short one I forget)- Sold my RS *sniff and had this axle I was going to put in it but never did. Its BRAND NEW bought at autozone, have receipt but they probably won't honor the warranty since it has my name on it. Its kinda obvious but its is for 420A only including avenger excluding Spyder GS. Asking 50
Pocket Logger Cable- PDA was in the fire I can send you the software and registration also. $20
OBD2 Extension Cable - Used once I think to verify it worked and never used again, don't really have a use for it since the flash plug has to follow it anyway. $15
Willing to meet in or around San Jose area, open to offers and trades as well.
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
