gsx gear in gst tranny.
5th gear is the only one, and it is shorter than the FWD 5th gear.
AWD has the tallest 5th gear ratio, if swapped to a FWD trans it would raise the top speed.
gsx i think have stronger front differential with ball bering , fwd have taper roller bearing .
sorry for question like this i try bulit my tranny stronger like stock i kill allready 2 transmission every time broke 5th gear .
ok 2g gst 5th gear ratio 0.741 gsx 0.666 for me gsx 5th gear is faster . (666 devil inside ?? ;) )
where i can buy output shaft for fwd ??? i have 3 tranny with broken gears for gst and 1 for gsx :(
