ECMlink GM MAP install
rinmancustom
82
Feb 15, 2009
wixom, Michigan
Need help. I just want to know if I hooked it up right and how do you tell DSMLink 2.5 how to log it. I soldered three wires from the factory harness to the GM MAP sensor then soldered three wires into the stock MDP sensor. I know the wires are into the right location but are you supposed to take a wire and put it into the ECU? I don't know.
Here's a page from long ago on how to install a GM 3-bar sensor on a 2G:
GM 3-bar install on 2G
Also, you can watch demo #3 on this page for an explanation of how to log the item using the ECMLink application.
ECMLink demos
You will need to download and install the V3 application first, but that's easy:
ECMLink Downloads
And then go into "configure connection" and tell the ECMLink application that you've got a 2G V2 ECU and it should connect fine.
Thomas Dorris
