Glant vr4 rear steering in eclipse?
Winall
Jun 3, 2004
Yuba, California
I searched on this topic and could not find anything, but I was wondering if that would help with the understear. Any output from a vr4 owner/driver on the handling of that car would be apperiated. If rear stearing is very help full, would it be worth the attempt to swap it over to a eclipse. The combo of rear steering, 35/65 centerdiff, and a good suspention, would make the car more netural.
no you don't want the rear steering it sux.
most vr4 owners remove it for better handling.
Defiant said:
The torque split on DSMs is 50/50. Don't even start down that road. :|
You are right, I ment to say with a aftermarket diff.
Geometry massaging and skilled driving will remove 90% of the understeer. Actually, intelligent driving alone will remove it all, but additional suspension massaging will allow non-understeer behaviour at a higher velocity for that same driver.
The only 35/65 centre diff available carries its own problems, although I suspect those issues would probably not raise their head outside of autocross or loose surface rallying.
Rear steer will only add weight and complexity - there's a reason it is missing from virtually all road vehicles.
Suspension adjustment and driver training are really all that's needed unless you're trying to win a National championship.
Charles
