Gauges problem, wont lid up :(
SexperT
374
Jun 13, 2005
Phoenix, Arizona
Ok, when i baught the car the gauges that mark the rev+boost + fuel+oil pressure+speed blah blah they lid up and had this switch that i could change its colors from blue to green and a turnable button that i could make it brighter or not, now it doesnt lid up and im getting frustrated cuz it doesnt look neat plus i cant see S***t at night. I unscrewed the switch and checked the back for any disconnections ect...nothing.
Here is my real question, when i floor it when i shift (fast) the lights turn on for about a second and then shut off once again, any ideas?? My boost gauge and my air/fuel mix gauge work fine and do light up.
Any help will be very apreciated guys, thanks.
so i gotta replace em?? i gotta take all that thing out?
p.s thanks for ur respond bro, i apreciate it.
Yeah, most likely you'l have to take the gauge panel out and replace them...
The interesting part though is when you mentioned that at high rpm/shift they'll lit up for a second, now... have you check for a wire making a false contact or bad grounding?
maybe when you're driving at high speed and shift the conection behind the gauges shakes and creates the conection work because something may be loose back there... you should check that. but be careful because clearance back there is very tight.
