Gaskets driving me crazy
birdman24
Aug 30, 2010
Cleveland, Ohio
Hello Im currently rebuilding my engine and I for what ever having a very hard time trying to figure out where some somethings go. The gasket kit in question is a felpro from extreme psi.
Gasket kit:EXTREME PSI : Your #1 Source for In Stock Performance Parts
I cant figure out where the "4 o-rings" are supposed to go, Im assuming that the "distributor O-ring" could be for the C.A.S but there are two of them.
Also there are 4 throttle body gaskets, Im guessing that since there are to different basic shapes of the gaskets that Im supposed to find the two that match the size of my thorttle body and put them together?
Any help is appreciated thanks,
Terence
i didnt know that gasket kits come with injector o-rings sense they come with new injectors? bryan is right tho there is some extra gaskets left over, at least i had a few after my build.
Every gasket set I have ever bought has come with orings for the injectors
Some of those gasket kits are just generic so they come with 1g and 2g gaskets. A buddy of mine did a head gasket kit and it came with t25 gasket and 14b gaskets and a whole bunch of other stuff. My head set came with both t.b. gaskets and a few other random ones.... depends on the supplier and/or vendor.
Thanks guys, yea I looked on Jnz.net and saw all the different throttle body gaskets for the different years. The O-ring gaskets in still unsure of but I'll try them on the injectors since this is a cyl head gasket kit I dont know where else they could go. The dipstick is possible but you would think that was in the block portion of the gasket kit.
Does anyone know what the two "distributor o-rings" could be for? They are much larger than the four smaller o-rings.
Also, am I supposed to put the two throttle body gaskets together in the same location? I have one that matches the Intake manifold perfectly and I have one that matches the throttle body.
Terence
Yea every headgasket kit ive got comes with every gasket ring etc from the head up and id jus go wit one gasket per location
