gasket set help, where they go?
Exxxel
99
4
Mar 18, 2006
Italy, Europe
Hi,
Please help me with this stupid problem....I'm going crazy, i cannot figure where these gaskets/orings go...
I know this kits are designed for both 95-99 7 & 6 bolt, but i want to be sure to install all the necessaries on my 7 bolt...
Thanks for help!
Two of those O-rings are probably your water pipe O-rings and in the lower picture One is probably for the CAS that fits in the end of your intake cam but since you've got a 96 you probably don't have that style CAS.
I also agree on the water pipe and cas, I also think on is for the sandwhich between your oil filter and housing. I got one of those kits a while back and im pretty sure one of those fit that oil cooler > housing.
Half of those o rings and crush washers won't be used, the kits usually come with a bunch of random ones, along with some little tiny valve seal looking seals that go no where on these engines.
