Funny noise
EVTBernie
85
May 4, 2006
South Burlingto, Vermont
Ok so I got my engine swap done and when I went to move the car I get a funny noise coming from under it. Only when the car moves does it make this sound. Im assuming the drive shaft is clanging the exhaust. Anyone have suggestions on how to adjust the exhaust so it wont touch the drive shaft? The noise also gets louder when the car goes faster too. I am running a full 3' turbo back too if that helps.
1) You should be able to jack up your car and see if your exhaust is hitting your driveshaft.
2) Did you bolt the bearing bracket on the driver's side front axle back onto the block? There are two 14mm bolts that secure the axle bearing to the motor. If this is off, the axle can "jump rope".
3) Check clearance of your front drivetrane. If you jack up the front of the car, you can turn the axles by hand and see if they hit anything. The spring will extend, so the sound may not occur.
4) If the car makes the sound at very slow speeds, have someone walk along side to see where the sound is coming from (front, middle rear, left, right, etc.).
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
