Fuel Pump on AEM EMS 30-1300.
LuizHGato
30
Apr 16, 2005
Fort Myers, Florida
Guys ... I have a problem, I have a aem series 1 on my 1G ... and she can not turn on the fuel pump .. anyone ever had a problem like?
thanks
I developed the same problem late last summer also Luizhgato. The car died on me on me driving home late last summer and after lots of testing and trouble shooting i narrowed it down to the AEM series 1 ECU is not sending a signal to the fuel pump relay. I then sent the ems to AEM for repairs and they said the ECU is good and they found no problem the ecu passed all repair tests. I now have to install the EMS back in the car and see if it turns on the fuel pump which i haven't done yet due to the harsh winter we had this year in eastern Canada. Please keep me updated on your progress with this problem and i will do the same ... in the coming weeks i will be installing the ecu back in the car and see if the problem is gone. I will also be taking the car to the AEM tuner i use up here in Canada to see if it was a malfunction i the programming.
A malfunction in the tune/programming wouldn't exhibit complete failure of the pump like that. If you said it was intermittent then I could maybe believe something in the cal would be causing that but not a complete failure and refusal to start working again.
thank you for the response sir ... what exactly is the cal
Thank you sir for the clarification on what cal is ... im going to take the car back to the AEM tuner and i think re-doing the tune will solve the problem.
I had issues once, it was due to a poor ground for the fuel pump relay for AEM.
