BoostedBeaver
Moderator
- 957
- 294
- Aug 15, 2009
Augusta,
Georgia
So I had to drop my tank and have it cleaned on my 90 talon. Reinstalled everything and she runs like a dream, but when I cut her off she losses all of the fuel pressure within 2-3 seconds it is that fast but there are no leaks to be found. Just wondering if you had any ideas on what I could check and once again there are no fuel leaks and the car runs awsome just takes a min to start cause I have to build fuel pressure. Could it be that I have a walbro 255 on stock fpr and the pressure relief valve isnt closing on the pump and that is why I lossing all the pressure??? Any help is appreciated thanks
Yes the walbro is rewired but that would have nothing to do with the pump loosing all its pressure after it is turned off. The only high pressure fitting that I took off was the fitting from the sending unit. Checked it and it is fine. Must be the pump.
