Slippi84
- 4,454
- 20
- Jun 8, 2005
Cinnaminson,
New Jersey
NosLaser said:If fuel went straight from the tank into the combustion chamber like a hose, then yes, you'd have to worry about it more. But it doesn't. It stops at the injectors and there is plenty of fuel that isn't being used that finds it's way back into the tank. A wet kit supplies it's own fuel independant of the injectors, so as long as the pump supplies enough pressure to keep the motor happy with the amount of fuel "lost" to the nitrous fuel line, then you don't have to worry about it. A wet kit is pretty self sufficient. If you get pressure drop from adding a wet kit, chances are your pump was pretty near maxed out already on 'motor.'
Regards,
By the way it's not "on motor" if your boosted but ill give you the "benefit of the doubt"
I think most of us with DSMs are thinking along the same lines. With a small turbo like this and a typical amount of nitrous being used, there are intank pumps that supply more than enough fuel. For an all out race car or a NT that plans to make all its power on nitrous, the fuel cell then seems a little more worthwhile...
