Fuel Filter Change!!! HELP!
gsnoturbo90
106
Aug 5, 2005
East Norwich, New York
Alright i really wanna change the fuel filter on my 90 eclipse gs. I was just wondering where it is, is it hard to change, is it worth it? I also plan on changing my injectors just to new oem probably,just something clean, or can i clean them out? I am new at the who do it my self thing, i can change my own oil and brake pads so is that something i can do or no? thanks
Changing the fuel filter is not hard, its located on the left side of the firewall and looks like a medium sized black canister, you jsut have to remove the two fuel lines going to it and then jsut swap it out, pretty easy. As far as changing the injectors, thats not really that hard either, there are 3 bolts that hold the fuel rail to the head, undo these and jsut carefully pop the rail out one injector at a time. Quick tip: whe installing the new injectors, put a tiny bit of vaseline on the o rings so that they pop in easier. Good luck.
