1. Join the Community!
FS: 95 Eagle Talon Tsi Shop Car
Posted by layzie12g, Oct 1, 2012
Please Support Kiggly Racing
Please Support ExtremePSI
  1. layzie12g
    layzie12g Proven Member
    119
    Joined Jan 7, 2008
    Seattle, Washington
    SOLD
    This is my personal/shop car (CLEAN TITLE) that is for sale. I run a small shop in Seattle called Ground Vision Performance and the time as come to move on from this car. It has been my baby for years and years. This car comes with at least $30,000 in receipts. It has 137k on the chassis, 900 on built motor, 1,000 miles on tranny (2 street launches), and it has brand new OEM style carbon fiber hood as well as a baffled valve cover. The car was in the reader's rides section of Modified Mag a few years ago, but A LOT has changed since then.
    This car has years of my blood, sweat, tears, and yearly wages. Everything is done right. Body as well as the interior is extremely nice. It does have a few little dings here & there, but still in factory paint. Currently the rear seats, rear side panels, and carpet are out of the car and I have got about half way through install S&W Racecars 8 point roll bar. The main hoop is tacked in. I can either put the interior all back together or leave the main hoop tacked in and you can finish it. The driver seat and passenger seat are in the car. It has been stored inside the last three years. The engine bay on this car is cleaner then the pictures can show.
    This car has no big issues. It does not smoke, leak, burn oil, grind, or do anything else it shouldn't. It is tuned at 28 psi on 92/meth. The transmission has a welded center diff and cryo treated gears. This car will make over 700 crank horsepower with this setup on pump gas/methanol. This car will trap 130+mph easy. Groundvisionperformance.com has a few more pictures including the background of my site.
    If anyone is serious about buying the car please give me call with any further questions. You will NOT be able to get a traditional auto loan for this car. If you do not have cash or any intentions of buying the car please do not contact me.
    $11,000
    NO TRADES AND PLEASE DO NOT LOWBALL ME
    206 909-6298
    SHORT BLOCK
    4G63 6 Bolt
    Ground Vision Performance 2.0
    Balanced & Blueprinted
    Torque Plate Bored & Honed
    Main Line Hone
    Mahle Forged Pistons
    Scat H Beam Rods w/ Arp Rod Bolts
    Micro-polished OEM Crank
    ACL Tri-metal Race Bearings
    Arp Main Studs
    OEM Oil Pump w/ Ported OFH
    HEAD
    Arp "L19" Tool Steel Head Studs
    Felpro Perma-Torque Head Gasket
    Supertech Dual Valve Springs w/ Titanium Retainers
    Forced Performance 3x Cams
    2G Unported Head
    TURBO & EXHAUST
    Precision Billet Wheel 6262 (Ceramic Ball Bearing)
    4" Custom 304 Stainless Intake
    9" K&N Filter
    Tial 38mm Wastegate
    Slowboy Racing Tubular Manifold
    Ceramic Coated Custom 02 Housing
    3" Turbo Back Exahust
    FUEL
    Aeromotive 340 Intake Fuel Pump
    Fuel Injector Clinic BlueMAX 1550cc Injectors
    STM's -6 From Tank To Rail Kit
    Fuel Lab "Mini" Regulator & Filter
    ENGINE MANAGEMENT
    ECM Link V3
    Speed Density
    Omni 4 Bar Map Sensor
    Plx Wideband
    Autometer 45 Psi Boost/Vacuum Gauge
    Autometer Oil Pressure Gauge
    METHANOL INJECTION
    Snow Stage 2 Kit
    VC100 Controller
    Dual Nozzle Kit
    High Pressure Pump
    2.5 Gallon Reservoir
    Anti-Siphon Solenoid
    GVP Mounting Shelf For Pump/Reservoir
    TRANSMISSION
    Built By Andre Of Pina Motorsports
    Cryogenic Treated Gear Set & Pins
    Welded Center Diff
    Phantom Grip
    ACT 2600 w/ Sprung 6 Puck
    ACT Flywheel
    SUSPENSION
    H&R Race Springs
    KYB AGX Struts
    Road Race Engineering Rear Strut Tower Bar
    STM Rear Camber Kit
    BRAKES
    Brembo Cross Drilled Rotors
    Hawk Pads
    BOLT-ON & MISCELLANEOUS
    JMF Race Intake Manifold
    Phenolic Intake Manifold Spacer
    1G Throttle Body
    GVP Coil Pack Bracket
    Kinetic Intercooler Short Route w/ 1/4 Inch Thick Custom End Tanks
    Custom -10 Valve Cover & Catch Can
    Greddy Shift Knob
    A/C Deleted
    Prothane Mounts
    Powersteering Retained
    Battery Relocated w/ Shut Off Switch
    2GB Bumper And Headlight Swap
    Tial "Q" Blow Off Valve
    345  0
    1995 Eagle Talon TSi AWD
    12.257 @ 115.730 · 2G DSM
    Loading...
  2. layzie12g
    119
    Joined Jan 7, 2008
    Seattle, Washington
    Sold
    345  0
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
