freeway egt temps high?
96nwgsx
Jul 4, 2004
tigard, Oregon
What are normal egt's for cruising on the freeway between 60 and 70?
How about long hills?
My car runs betwwen 1400 and 1650+.
Am I way to lean or is this normal?
Thanks for the help :dsm: :thumb:
@ 75-80 MPH , 3200-3500 RPM on the highway I'm usualy around 800C. Considering under that condition the motor is in closed loop and running an AF of 14:1, yes thats normal.
What happens when you punch the throttle. My EGT drop a tad then stabilize @ 825-850 or so. You;ll need to look at your fuel trims to really figure out if your lean @ low throttle.
