Fixing rust in rear wheel wells?
esoteric
160
Jul 19, 2010
PA, SK, Canada
I noticed that there seems to be surface rust under the black near the bottom of the rear wheel wells it looks like its around a plug or something facing the front.
Curious how hard this is going to be to fix? I am not even sure what is behind that. :boring: getting pretty sick of rust.
if its just surface and not through, sand it down to the metal then spray it with ruberized spray paint
i just rebuilt that same spot on my girlfriends esi it was completely gone so i used screen and bondo then sprayed it with rubberized under coat and you cant tell there was ever a hole there.
Remove the undercoat so that you have the rust as well as about an inch and a half of paint around it. Then grind the rust down with a 40grit flap wheel or similar. After all the rust is gone, sand the paint leaving about a half inch left before you hit undercoat. Apply rust converter to the area the rust was. Once that's set, etch prime it all, then reapply undercoat.
I had to remove my sideskirt on my Talon and replace the rocker, wheel well, and pinch welded seam. I still have to do the driver side.
