finished the 14b install!!!! avcr questions?
ohio98eclipse
365
Aug 4, 2003
Ok so i finished installin the 14b and i readded coolant and oil and boom coolant leak..forgot to tighten a line behind the turbo...pain in the ass had to take it all off agian!!..anyhow its all fixed now and i have no leaks and i took it for a drive and its nice..but my question is i have a apexi avcr and on my t25 i would run it at .75 boost and about .45 duty than it would learn it self and thats about a solid 15-16 psi...now on my 14b turbo in order to even hit 13 psi( and thats a spike!!!) 11 psi constant i have to turn it all the way up to 1.30!! and .62 duty...thats like double of what i was runnin before......i was wonderin if this is normal??? if i have a boost leak maybe?? but the shit pulls strong ...anyhow if you guys have any answers id really appreciate it!!!
btw my mods are..
apexi 3" cat back
blitz bov
injen intake
and other light mods
Also what is the max psi i can run on a 14b turbo with stock injectors and fuel pump??? i ran 16 on a t25 with no problem...just let me know
OK Ohio, I wouldn't run that 14b too hard on the stock pump. ASAP get a 190 or 255lpm. That will allow you to run 16psi safely. And make your life simple and run a manual boost controller.
