Fiberglass enclosure pics: SET3
bOOstd GSX
931
Nov 29, 2003
Plum, Pennsylvania
Not much has changed just wanted to take some better picstures and put the nitrous bottle in to show you how its gonna look:
hey man, quick question.. is that bondo over the fiberglass? i'm almost done with my lip and heard something about bondo being bad because it doesn't flex???
help me out!
nice trunk btw, any subs?
Ya its bondo, I've done two other enclosures and they haven't even begun to crack or anything and one of them is in a daily driver and done over a year ago.
I have two kicker solobaric L7's and a 10 inch L7 and some mids and highs, two 1600 watt amps an in dash dvd player, 2 screens, etc. PM me if you have any questions.
No this bad boy is installed and installed for good. Since the engine that I'm having built is making over 600 whp without nitrous, this little bit of extra weight isn't hurting anyone.
Just curious here, but whats gonna be put on that beast of an engine? I want 600 whp :thumb: :dsm:
Say these mods:
Modified Stroker block (6 bolt crank platform)
Fully Cryoed block, crank, rods, and pistons
GReddy big front mount
GReddy Plumbing
GRedyy Type S
990cc's
Weldon racing pumps
AEM EMS
Custom Wiseco Pistons (8.5:1 ratio/.020 overbore)
Eagle Rods
ARP main studs
All new freeze plugs
Balance shafts removed
Butcher crank
New oil pump front cover
New oil drive gears
Line hone, torque plate boring, decking, and plateau honing of block
Assembly of shortblock
Balancing and blueprinting of rotating assembly
File fit rings
All new bearings
1G reconned oil pan
Cryoed Level 3.5 head (1mm oversized valves)
New “big hole” lifters
Head “wings”
Crower spring kit (titanium retainers/springs)
HKS 264/272 Cams
New cam seals
Cometic head gasket
Fidanza adjustable cam gears
1G Coil Pack
Powercoated rocker cover (your color of choice)
1G T-Stat Housing and outlet
’90 CAS
1G Water Pipe (refurbbed)
Lower Radiator Hose
Magnecore Wires (1G)
1G Water Pump
New Timing Belt Cover
Timing Belt Undercovers
Magnus Sheet Metal Intake
Fidanza Aluminum Flywheel (6 bolt AWD)
Stainless steel rocker cover and oil pan bolts
1G timing belt kit
Modded motor mount (timing belt side)
...all of this on a 6bolt in a 2G GSX.
this isn't all of the mods, or the nitrous.
