feels like it wants to die after i rev it
1990ill_eagle
44
Oct 4, 2009
houston, Texas
my car seems to run fine until i rev it then the engine starts to shake and it nearly dies please help?
its on the decel and no fpr
i just have a stock blow off valve the car ran fine but i just recently replace the head and it started acting up. another thing im getting an almost rythmitic noise comming from the egr/throttle body area its like a grinding sound could this be a problem?
Uhm... Check timing?!?
i checked it with a timing light its sitting AT 10 deg. before top dead center. Could my base timing be off?
ok so that grinding noise is comming from my throttle position sensor> i put a multimeter on the wiring harness connecter and the ohms are jumpin between different setting just like that rythmitic noise i was hearing. I just recently replaced the dash I have a 1990 and the dash i put in is from a 93. Could this be the problem because i used the 93 wiring harness instead of the 90 wirirng harnes?? PLEASE HELP!!
sorry for wastin your guys time but i switched out the 93 wiring harnesss for the 90 wiring harness and wala problem soplved. Thanks for the help though
