Exhaust Pops and Flame with Cat or No-Cat?
TheBigPhantom
82
Apr 10, 2007
Niles, Illinois
I was wondering if anyone on here knew if the exhaust would pop more and produce flames or fireballs (backfire) without a catalytic converter or if it would more likely occur in a car with a cat.
I drive a 95 GSX so use that as a foundation when talking about how to produce this effect.
Yes it will pop more and shoot flames easier without a cat. The cat is part of emissions but it also acts as a muffler.
The way I was told to get the flame effect is to. Take the cat off an get dsmlink an turn on the antilag control on it. I read that if you set it up right you can shoot fire out your exaust like that. The down side is it also kills your turbo. Another way is use nitrous a 50 shot will do from what I read. My question is why owuld you want to be a ricer? Or do you just want to try it out one time an see? I think it would be cool to see, but not do all the time. FaF is fun to watch but you get more chicks from power than looks.
Vented BOV... The ECU thinks that air is there, it's not, you got fuel in your pipes and BOOM.
With correct air fuel ratio you can explode your pipes, mufflers, turbo and exhaust manifold. I've seen aftermath of in pipe explosion myself, it's neither pretty, nor cheap. ;)
And pray your half empty fuel tank is not in a way :rolleyes:
Maybe not, but maybe it will if you have badly tuned engine. I can't find pictures of such explosion aftermath on our local dsm portal :(
RS can be recirculated as it should be. I have one, you just need an adapter. And with good filter like Apex'i it sounds almost like vented.
Hmm...well apparently to answer the OP's question, there seems to be a variety of things that can cause this.
To start a little list i've gotten,
1. bad cat.
2. Vented BOV.
3. Turbo bearings gone bad?
4. Compression.
5. bad plugs/wires.
and last but still my fave.
6. 87 octane gas. (X
Like This???? (this is me in my car btw shooting the flames on our way back from the shootout.....YouTube - Chad shooting flames)
I solved it by fixing a leak in my exhaust. My o2housing was being held on with one loose bolt and there was no gasket. I run my wastegate off of the o2 housing, so this really messed with my tune. I fixed the leak with a new gasket and 4 new bolts, and no more flames. :thumb: It was f-ing sweet though, the look on peoples faces...ROFL
Well I its was more of an I want to make my car be able to do this once in a while.
I already no the stutter box on the DSM chips and DSM link can do this but I've seen it happen on SRT-4's when they are engine breaking or shifting.
ALSO i thought that it would happend more often in a car WITH a cat because the cat burns the fuel making an explosion?
I've heard that if you block of the EGR and use a studderbox it would sometimes shoot flames but thats only what i have heard. Only way I know of how to shoot flames is use an ALS system like the above poster stated.
3. Don't try to help if you don't know the answer - bad advice is often worse than no advice (no "I think" or "I guess" or "I've heard").
YES! mine shoots flames and holds a flame when i let off and engine brake...and now right as it done shooting it skips for a sec???
