exhaust popping
josherino
148
Sep 18, 2004
Ft Collins, Colorado
my exhaust is popping about 1 time every 2 seconds when driving with constant pedal pressure. Is this an ignition problem? I recently replaced almost everything having to do with the ignition system because of past problems. It doesn' t pop at idle really only while driving and not accelarating.
I don't know but if I had to guess, I would say that you are correct. I put a new very upgraded fuel system and I have not tuned it yet. could that be the problem?
ugraded what? like the pump and injectors? if you changed out the injectors than yes chances are they need very badly to be tuned. just a pump shouldn't cause you to run rich.
