evo3 16g or td05 18g
In 3rd on a level road my 18g hits 19-20 psi by 2900-3000 rpms, Im running the ceramic pacesetter header and AMS tubular 02 housing. I was surprised, it spools quicker than my 14b did @3200rpm, although I had 2 cracks on my mani and a nice long crack around the turbine housing scroll upon inspection when removed.
in an earlier post the holset tdO4 was said to be superior over the AGP rs52.. but why. the rs52 flows more per minute and has a bigger compresser wheel.
Its a Td04 in a BULLSEYE turbine housing and it was said to be a better deal than a 16g or and 18g....
The AGP RS is nice and guess what? AGP uses bullseye housings...
There is no such thing as a Tdo4 holset....
Bullseye makes a turbine housing you can bolt a holset CHRA to...
Do you know what CHRA means?
More reason not to get the EVO 16g when you can get that TO04B with the bullseye housing and wastegate...
Boost creep
http://www.dsmtuners.com/forums/showthread.php?p=1342678#post1342678
