Evo X Fuel Pump
kiddsm95
154
Mar 23, 2007
Ann Arbor, Michigan
Does anyone know if the Evo X fuel pump is a direct drop in for the 2g's? What is the Evo X fp comparable to a 190 or 255?
Do you have any pics of it? Evo8 & 9 are direct fit 38mm pumps for 2g. Not sure about evox. You should be able to get it to work with little modification, I would assume if its an oem denso.
Do a search for AMS fuelpump tests. The EVO X pump rewired flows 192 liters/hour @ 70psi. The rewired Walbro 255 HP pump flows ~209 liters/hour @ 70psi. Although much better than the EVO8/9 pump and Walbro 190 pump, the EVO X can't flow quite as much as the 255 HP, but is almost identical to the flow of a rewired regular 255 pump (non-HP).
Jeff O.
http://www.dsmchips.com
SUPPORT: DSM Chips :: Index
  • Wanted 6 bolt NT water pipe
    • chrisman287
