evo 560 injectors?
kevbojunior
116
Mar 3, 2008
Cheyenne, Wyoming
will these be enough for an e316g at 23lbs? ive heard different thing but never really got too much input on it.
I think you will be pushing them to the limit if not beyond... They would have to flow perfect and i know the IDCs would be around 90-100% if not higher and that comes with the risk of sticking open...
yeah i have heard that and even heard of people with high idc's with 660cc too. im going to use a keydiver chip as well. im thinking maybe 880cc so then i have room to grow. the thing is my friend just put a red on his evo so he is going to just give them to me due to putting 880's in.
Youll have to wait and see when you log. They will definitely be pushed to the max though. If you dont have them already, i would consider going larger. I currently run them and have larger injectors that i'm ready to install.
I would get 650's and play it safe. Leaves you ample room for improvement as well.
thanks for the input guys. i think ill go 880cc ### in the near future im thinking of using a fp3052. maybe if i keep the car really conservative to like under 350whp i will use the evo injectors but i doubt that will happen. i know i can search this but what is the average power people are seeing with the e316g with 23lbs, cams and supporting fuel system?
It all depends on what you will be tunning with. Manny people have ran 10s on 550cc injectors tunning with a vpc.
yeah i think ill def go bigger than the evo injectors. if i ever put the car close to stock ill put the evos in.
