Gullett0003
- 0
- Dec 13, 2011
Creve Coeur,
Illinois
Hey guys. Ive got a huge headache on my hands. I used to own a 95 gs back in like '02 so im not unfamiliar with these cars but i dont know a whole lot. esp when it comes to engine internals and tuning. This is kind of an oddball question because of my application. I bought a '98 eclipse dirt track "hornet" class car. Its my first race car. When i bought the car it had a 2.0 DOHC in it that had a thrown a rod through the block. The good thing (or atleast i thought) was that it came with another 2.0 DOHC spare engine. The seller did not know any specs or mods on this spare engine so i took it to my shop to have to gone through before throwing it in. Well, the shop called me and it turns out it is highly modded internally. both of these engines had ported and polished heads with race cams. So, we took both the heads and combined them into one with the best parts. Crower stage2 race cams, adjustable cam gears, aftermarket valves (titanium i think the shop said), rollers, and springs. The shop called the pistons "high compression dome" pistons. it has a venom fuel rail and the mech said he thinks the injectors are aftermarket as well. the throttle body is ported. it has lightweight gears all over, and aftermarket header. The car has a module under the dash that say "jet" and lights up when the ignition is on. Those are all the mods that i know of...Now with that being said technically "hornet" class cars are supposed to be bone stock. Which is a rule that i hear is broken more often than not, so long as the car appears somewhat stock. Bolt-ons are overlooked...i just picked the engine up from the shop. the mechanic said its ready to roll and is set to top dead center. My question is what exactly to i need to run this engine? Ive heard megasquirt but seems to me it would stick out like a sore thumb under the hood and be a dead giveaway of internal mods. Also im not trying to dump a ton more money into this car. It cost me a grand to have the head work and everything else to get the engine ready. I dont need to get the absolute most out of this engine i just need it to run reliably under heavy, heavy stress. Does anyone have any ideas on how to do this? The guy at the shop said a stock ECU would burn up the pistons? The car came with about 5 ecus, one of them has a sticky note on it saying what the rev limiter is set at, does this mean i can roughly tune the stock ecu? Im just so far over my head, to make it even worse i dont have any reliable sources in my area. Ive searched high and low. I know this is a really long post, but thank you for taking the time to read it. Any input would be appreciated. If you need any more information than i listed, let me know and i will try to get it to you. Thanks so much!
