engine problem
Easiest way is to search the forums on how to build a boost leak tester, then get a air tank, pressurize your turbo and listen for a hissing sound. Just search on hear, there are 185789 different threads. You need to build one for 10 bucks. And it will then become your best friend.
Build a boost leak tester, get a spray bottle of windex ( it bubbles when air goes through it ) and start checking every pipe and fitting you can.
i had the same problem not sure if the correct problem buy my spark plug was foul so when i open it , it was fill with oil so ive change the gasket sealer for the plug and one of my injector lost it pin so it was loose well just check them
