Engine Compartment
Not a direct bolt in by any means, your biggest problem will be the motor mounts which you will have to do some custom fabrication.
Quoted by wiseman 92awddsm in a simmilar thread:
"You are going to have to fabricate mounts for both the firewall side of the block and radiator side of block,aka: front and rear mounts or roll stop mounts. Provisions for these mounts are not found on the 2g 7bolt block, therefore it is not a direct bolt in for the 1g. With these being the weaker, more undesirable 4g63's, most people wont waste the time making them fit when a 6 bolt drops right in. There was a thread from sometime last year of someone doing it but I cant find it right now."
See original discussion at the thread below:
http://www.dsmtuners.com/forums/newbie-forum/299892-2g-engine-1g-no-front-motor-mount.html
Good luck, with whatever you decide to do. :thumb:
