engine clicking
1988talon22
Jan 15, 2009
montreal,
hey guys i have a problem i took out my car out yesturday after i change the spark plugs ive gotten some shitty bosch platium and i thought the the old valve cover seal where good enough i didnt seal it and i think i didnt tight it hard enough as i drove it was fine then switch it to gear three then gas it up to 5 to 6 thousand rpm then i reached a very big back fire pulled over pop the hood the valve cover was not seal good enough oil splash out a little then drove home slowly then left it to check it the next day. after i started it, it making clicking sound as i rev higher the clicking get louder its very loud im not shure ### it is. its coming from inside the cyclinder head near spark plugs area is the loudess u guys thinik its a lifter if it is how do i check them or is it the valve stems or could it be something else help pls this is giveing me the creeps
I am not really sure what your wrote. You should use punctuations.
I would say get rid of the shitty Bosch plugs and get a nice set of Copper NGKs. The ticking could be the rockers ticking but I am not 100% sure.
I would change the plugs and seal the valve covers and see if the noise is still there.
  • Wanted 6 bolt NT water pipe
    • chrisman287
