Calan
DSM Wiseman
- 7,250
- 400
- Jan 16, 2007
OKC,
Oklahoma
Disclaimer: Beer was involved with this story.
So I'm dropping my rear sub-frame for my rebuild, and it dawns on me that I have a pumpkin full of brand new Redline Heavy Shockproof. And since this stuff costs about as much as a typical Honda, I decided I better try to reuse it.
Looking around the garage I spotted my handy-dandy-pressurized-gear oil-filler-upper can that I made from a 1 gallon plastic gas jug with a little HSP still in it. I also spotted a nice clean small funnel, and life was good.
I broke the drain plug loose, positioned the can under the rear drain with the funnel in the top, and proceeded to thread the drain plug the rest of the way out. This is where that beer/dumbass thing I mentioned enters the story.
Somehow the drain plug slipped through my fingers, and as luck would have it...turns out that not only was it designed to plug a rear diff, it was also designed to flip upside down and perfectly plug a small funnel. I never realized how fast HSP can flow out of the drain; I could have sworn that it flowed MUCH slower when I was trying to pump it in.
And I'm really amazed at how little of it the funnel can hold, because as I knocked the shit out of elbow and smacked my head on the lower fender well scrambling for something else to catch it in, I had just enough time to look over and see all but about 3 teaspoons of it flowing all over the garage floor.
I'm pretty sure someone snuck into my garage and put that other four gallons of HSP in my rear end that came pouring out, 'cause I only remember it holding a little over quart when I filled it up. Have you ever tried to wipe up a small pond of HSP?. It's like thick red KY jelly...which seems appropriate I guess.
Ok... back to the garage. I need another beer.
