Drive while on jack stands?
imagine3163
179
Aug 2, 2006
Newberg, Oregon
Hypothetical question: Say your AWD car is on 4 jack stands with all the wheels off of the ground. Could you put the car in gear and drive it to check for drive train related problems or will something get messed up with the absence of friction on the tires?
What made me think you couldn't is because when you spin one of the back wheels in one direction, the opposite side spins in the opposite direction. However, this is only because the driveshaft isn't rotating right?
yes, it will act like its on the ground when the ENGINE is making the wheels move.
u could tech. do this IF you are stable enough on the stands. i would like to do this to listen for drivetrain noise i have.
better to take it to someone with a LIFT and do it like that so its centered and more stable.
be careful tho!
I've run mine on the lift to 80 MPH. DSMlink said I was making 5,000,000,000 horsepower.
I had the wheels off, and the rotors bolted on with the lug nuts.
I don't think I would run it that fast on stands, and it was only for an instant.
If it's an auto, put it in neutral and shut it off before you put it in park.
Its because you have an open differential, hhhmmm wait a second, because the viscous coupler doesn't work unless in high heat it would still act open:aha:. Either way it spins the other way because its open diff at that moment.
What kind of driveline issue do you need to check by having all 4 wheels off ground?
  • For sale 1g Assortment of New, Used, and Unobtanium Parts
    All good stuff. Will sell individually or lot sale.
    • 8716valver
  • For sale 2g 95-98 Talon air bag.
    2g Talon airbag. Really good condition. Can ship ups ground. Message 702-741-6987
  • For sale Injen Intake System
    Good condition used Injen Intake System for Turbo DSMs
    • kyler021
  • For sale 1g 1G Driver & Passenger Door Jam Seals
    1G Driver & Passenger Door Jam Seals $50 + shipping & paypal fees* these are the door jam...
