down pipe questions
snowwhite1g
Apr 2, 2008
New Milford, Connecticut
So basically I'm converting from iwg to ewg I am going to fab up a custom dump for the waste gate, this is all fine and dandy. My questions start here; I want to make a custom cut out, piping the cutout and the ewg into the same pipe, the pipe would be about two and a half feet long and have probably about forty to sixty degrees of bend in it. Location wise the most Ideal place to run this cutout and ewg setup would be right off of the o2 housing. I would run the cutout perpendicular to the housing join that pipe with the ewg dump, on and out. I'm not sure if this will screw with my turbo setup, if it will have enough back pressure or what. The pipe in place would be close to the shape of my downpipe just continuing horizontally across the motor bay instead of heading downwards toward the back of the car. I'm not sure if anyone has any insight on the situation but every little bit helps, thanks.
  • Wanted 6 bolt NT water pipe
    • chrisman287
